1 - 13 of 13 Posts
Well long story short. I bought a long block red top sr20det off a buddy and it was missing a ton. My plan was to buy everything I need individually and piece together a full swap. Bought a ton of things to start putting her together and then soon realized i could just buy a complete swap for less. Not to mention i know so little about sr's that this is a bit over my head. Im taking a loss on most things, i plan on making enough off the sale of these to buy a blacktop swap and not deal with the headache. all prices are obo
everything can be shipped with exception to the tranny and the block. buyer pays
im located in hudson, new hampshire
sr20det red top ecu #62- 80$
sr20det red top intake manifold (fuel rail and injectors not included), not sure if its complete, everything shown in pics besides fuelrail and inj. are included- $35
sr20det cas BROKEN (can probably be fixed. i bought it off ebay in great condition for like 100$ but when transporting motor to my new shop it took a beating- 15$
sr20det uncut red top wiring harness w/igniter- 130$
sr20det starter- 60$
sr20det os giken twin plate clutch used but disks have plenty of life left. 1200$+ new- $350
sr20det red top valve cover w/ center section, would need to be cleaned up- $30
sr20det red top cylinder head complete with cams and caps, no need to shim, rockers are included- $200
sr20det red top cylinder head (needs helicoil on 1st exhaust cam cap and broken bolt on water neck machine shop should be able to fix), no cams but no need to shim and rockers and cam caps included75$
sr20det t25 complete turbo setup good shape (lines, mani, o2, etc), shaft is in good shape - 200$
sr20det t25 turbo (minimal shaft play) turbo only, needs to be clocked- 100$
sr20det tranny w/ harness and speed sensor- 150$ PICK UP ONLY
sr20det short block (previous owner rebuilt), but i never ran it, i was told it has arp head studs but i dont know 100%, should be all set to bolt up- 400$ PICK UP ONLY
sr20det coilpacks with harness- $40
sr20det tomei o2 housing, just purchased it new a month ago from 240sxmotoring.com still in box with all hardware needed- $150
infinity q45 maf- 30$
im best to be reached on aim- pemcnulty82, email is [email protected], but pms work and i only accept paypal.
1 - 13 of 13 Posts
