1 - 7 of 7 Posts
· Registered
alright you can physically thow the the tranny into any gear when your car is well not on, well for some odd reason my sr20det wont do that, it's like stuck i can go in to fifth we where fifth is supposed to be anyways, but no other gears. The car has not been started yet so i was wondering if the car needed to be started to be able to shift, or do i need to bleed the clutch more cause its real spongy, or if it was just my tranny has seized if that was possible.
· Registered
is the clutch pedel pressed in? My SR is hard to put in gear when its off and the clutch isnt pressed in. Do you have the stock clutch damper box on there? If so, remove that piece of shit and bleed the clutch again. Air gets trapped in the clutch damper causing bleeding problems.
· Registered
Discussion Starter · #5 ·
alright thanks guys cause i havent started the car up yet and it scared the crap out of me cause i thought it was seized but my pedal is really soft and it has a lot of air so i figured i needed to bleed the clutch
· Registered
when i first did my swap i couldnt either. after i started it it would go into fifth. then i drove it for an hour trying to get it to go in to fifth then it finally did. no problems since.
1 - 7 of 7 Posts
