So to start I have a 1991 s13 with an sr20det and tranny to match. I have a couple bolt ons the clutch was a red bunny kit old from the previous owner. I use a stand-alone so I got tuned made 330 at 15lbs My tuner told me that the clutch wouldn’t last but have fun with it for now and to come back once I got it replaced. I never did and eventually my transmission started to slip and smoke pretty bad whenever I was under boost. Eventually I replaced it with act 6 puck good for 576ftlbs and made it “future proof” if I ever wanted to make more one day. I though this fixed the smoking issue when I took it for a test drive and it did for about 2-3 hours then when going up a hill it started bellowing out the back but only when I let off in 3rd 4th or 5th after a pull. I did a small break in just slipped the clutch hard a couple of times as I’ve always done with pucked clutches. Anyways I’m just kinda stuck. I have a hunch that transmission fluid is leaking somewhere either out the top of my shifter, my shortened breather tube or out the draft seals it’s hard to tell because there’s fluid everywhere under there I’ve never cleaned it really. I think this is causing the trans to heat up and when under load the g force is causing the fluid to slosh to places with hot spots and burning the fluid causing all the smoke. I just wanted a second opinion on it as I don’t have many friends that have modified cars so they don’t really run into these issues like I do. All help or opinion would be appreciated I’ll try to get to back to everybody as soon as I can when I find a solution and just to see what you guys have to say. Thank you in advance -Logan
Ps. With the new clutch the transmission doesn’t slip when smoking
