Turbo KA 'bible'
78K views 117 replies 70 participants last post by  DVSone
Originally posted on KA-T.org by Veilside180sx
These are the Prerequisites to building a DOHC Turbo. Together we will go through typical setups from mild to extreme to reach the power goals you desire. These are lists of typically used items that are easily attainable by the average person. All setups should have the Air to Fuel Ratio verified on a dyno with wideband or at very least on a track using an in-car wideband setup (NO watching the standard O2 signal and calling it good). If your using pump gas and seeing air to fuel ratios more lean than 11.8:1-12:1, some rethinking on the tuning/fuel setup will be needed. A narrowband guage(typical A/F guage from Autometer for instance) is not complex enough to be a real indication of the ratios inside your combustion chamber.
Very Mild Build: around 180 rwhp
Turbo Manifold
Blow Off Valve
Turbo (T25)
Downpipe 2.5" is perfectly fine
Pipe to connect turbo to throttle body
Fuel Control:
FMU (not recommended, but doable) Raises fuel pressure per boost to make injectors flow more than normal.
SR 370cc Injectors. These can be found at places found at the bottom)
Apexi SAFC2
Greddy Emanage
Mild power adder, say you want around 200 rwhp.
Turbo Manifold
Blow Off Valve
Small Intercooler (potentially get away with a side mount)
Turbo T25/T28/14B, etc. Smaller T2 setups. Usually will be internally wastegated.
Replacing the Exhaust is starting to be very necessary at this stage, so I would start to shop for that as well.
Fuel Control
SR 370cc Injectors
Apexi SAFC2
Greddy Emanage
Back off base timing at distributor or MSD BTM
Average: 300 rwhp to 350 rwhp, you have to start to expect a little more lag. This is about the perfect "street car" limit. No race gas, just good honest street car fun that is fully capable of bring home a 12 second timeslip on a good run.
Turbo Manifold
T3/T04E .50 Trim compressor, .60 trim compressor housing / Stg 3 (aka TA31) turbine wheel, .48 to .63 A/R exhaust housing. Internal wastegate optional but not recommended.
Downpipe can still be 2.5", but this is as far as I would want to push that.
Front Mount Intercooler (FMIC) It's time to upgrade to a larger front mount as the larger will push more air than the smaller sidemount can cool.
Fuel Control
550cc Injectors
SAFC2 to control your fuel injectors, along with the stock ecu.
MSD BTM At this stage I would be running the BTM to control timing retard.
Reflashed ECU-This can be a DIY thing with Megasquirt Tuning or a JWT.
Z32 Maf is required, as the stock Maf stops being able to read at around 260 rwhp.
Wideband O2 Sensor should be installed for tuning.
Block Internals
This is where I would start to consider it necessary to replace you pistons.
Above Average: 350 rwhp to 425 rwhp
Turbo Manifold
Blow Off Valve
T3/T04E 50 Trim .48/.63 or slightly larger turbo, this is where I would start to make the switch up to an external wastegate. You have the option to reroute it back into the exhaust, or merely "dump" it out into the open. "Dump" is usually a mini exhaust in the form of 1.5" piping routed out to the open.
FMIC Larger is starting to be necessary. Typical for setups from here on, are 12"x24"x3" for the core.
Downpipe 3", at this point I would switch to the larger downpipe. You can probably get away with it at 2.5", but it will be causing a little bit of backpressure. Moving to 3" piping as quickly as possible is what you want though. Usually it is necessary to have the first bend 2.5" to clear the steering shaft though.
Exhaust 3"
Block Internals
At this stage you'll want to "build" or fortify your block to better handle boost. Previous to this you can walk the line, but here and forward I find it necessary to do so.
Forged Rods
Forged Pistons
Stock Crank
Plus your typical rebuild items.
Fuel Control
Standalone fuel management is recommended at this stage in the game and is absolutely necessary at the next. These allow you control not only very large injectors, but the tuner to have complete control over both timing and fuel.
720cc Injectors.
Wideband O2 Sensor is necessary for tuning.
Wild Build: 425 rwhp to 600 rwhp. Lag is obviously going to be much more apparent, full boost isn't going to happen until around 4000-5000 rpms or so. Once spooled it will pull very hard.
Turbo Manifold
Turbo T3/T61/SC61 or GT35R seem to be the typical turbo's in the area. External Wastegate is your only option that should be considered.
Blow Off Valve You'll want a good performing more expensive blow off valve to alleviate reverted air when the throttle body closes from pushing against the compressor wheel.
FMIC the 24"x12"x3" Core's are still effective in this range.
Downpipe 3" is still capable of handling these power levels
Exhaust 3" or larger
Fuel Control
720cc-1600cc Injectors
Standalone Fuel Management
Recommeded to switch to Map instead of Maf for reading airflow.
Wideband 02 Sensor installed and wired into standalone for adjustments and monitoring.
Dyno tuning is very valuable.
Block Internals
Along with the previously mentioned internals I would add these to the list
Cams (per your discretion)
Build your head as well
Valve Springs
Valve Retainers
ARP Head/Main Studs
Cometic Headgasket or similar
Absolute turbo necessities...amongst the aforementioned goodies above.
Oil Lines (Picture of good return location)
Fuel Pump:
The stock pump is decent but not intended for such use. For Walbro 255's being as cheap as they are, anyone turboing their vehicle should upgrade previous to turboing.
Boost gauge
Here's lists of aftermarket products that are currently on the market
Turbo Build Parts:
Turbo Manifold (Exhaust Manifold)
Ground Zero Motorsports
Full Race
Peak Boost (release date TBD)
Revhard
Turbo240.com
JGS Precision
Realnissan.com
Import-AutoPerformance.com
Nizzx.com
SSAutochrome (not recommended)
BOV
Tial
Greddy RS
JGS
HKS SSQV
Wastegates
Tial
JGS
Turbonetics
Block Internals
Pistons: Can be accomplished one of two ways, by purchasing ones that are made for the E with their intended compression ratio. The other is to use DE pistons and subtract a full compression point to equal the difference between the E and DE head. (ie 9:1 DE pistons will be 8:1 in an E)
Arias 8.8:1(DE)
Wiseco 9:1(DE)
JE 8.5:1
Ross 8.5:1(DE)
CP 9:1(DE)
Supertech 9:1
Rods: Any rod that will fit the bottom end of the DE will work with E as well.
Crower
Pauter
Carillo
Eagle (release tbd)
Bearings
Whatever your preference is for rebuilds. Mine is Clevite.
Headgasket
Cometic
Valves
Supertech Dual Valve Springs
SI Valves
Ferrea Valves
Retainers
Supertech Titanium Retainers
Cams
PDM Racing
Nissan Motorsports
Colt Cams
Crower
JWT Technology
Typical Injectors Used on DOHC
SR 370cc Injectors
SR Upgrade Injectors are available in various sizes between 550cc-720cc as side feed, anything larger usually you'll want to switch to a top feed fuel rail and injector combination.
Injector Resistors (To alter low impedence to work with a high impedence ecu)
JWT Technology
JGS Precision
Sorry Just got sick of seeing all these can i boost my KA questions.
there it's stuck. and btw i've been gone alot lately i'm training for a new job. And Fidelity keep your fingers crossed I think you're about to get lucky. ;)
#16 · (Edited by Moderator)
KA24E/DE Turbo Manifolds
I have Seen Countless threads of ppl asking what manifolds are avaliable and such so I decided to make this thread.
www.StreetImports.com
Material - T304 SS
Turbo Flange - T25/28
Wastegate - Requires Turbo w/ Internal WG
Style - Tubular
Price - $299
www.RevHard.com
Material - Cast Iron
Turbo MAnifold - T4
Wastegate - 35mm External
Style - Log
Price - Depends on Vendor
www.GroundZeroMotorsports.com
Material - N/A
Turbo Flange - T3
Wastegate - 38mm External
Style - Equal Length
Price - $800
www.JGSTools.com
Material - Cast Carbon
Turbo Flange - T3
Wastegate - Fits Most Deltagate & Tial 35/38 External
Style - Log
Price - $380
www.SSAutoChrome.com
Material - SUS 304
Style - Tubular
Price - $250
Material - Sus 304
Turbo Flange - T3
Wastegate - N/A (Looks Like External - No Specs)
Style - Equal Legnth
Price - $225
www.TurboBoss.com
Material - 304
Turbo Flange - N/A
Wastegate - N/A
Price - $350 -$550
www.HKTuning.com
Material - 304
Turbo Flange - N/A
Wastegate - External
Price - N/A
www.TopSpeedAuto.com
Material - SS
Wastegate - N/A
Style - Tubular
Price - $259
www.Import-AutoPerformance.com
Material - N/A
Turbo FLange - T3/4
Price - $749
www.JGYCustoms.com
Material - SS
Turbo FLange - T2
Style - Tubular
Price - $307
www.Full-Race.com
Material - 8 Gauge SS
Turbo Flange - Dosen't Say But I Belive it's a T3/4
Price - $1,149
Phoenix Turbo
Material - N/A
Turbo Flange - T3
Wastegate - External 38mm
Price - $899
www.TopHatPerformance.com
Material - 40 SS
Turbo Flange - N/A
Wastegate - N/A
Price - $650
Can't foget about them SOHC Guys can we?
Of course not :D
:ihit
www.GladmanPerformance.com
Material - n/a
Turbo Flange - n/a
Wastegate - Optional
Style - Log
Price - $250
www.JGSTools.com
Material - n/a
Turbo Flange - T3
Wastegate - 35/38mm Flange
Style - Log
Price - $380
www.Import-Autoperformance.com
Material - n/a
Turbo Flange - T3/T4
Style - EL
Price - $750-800
wel concerning that the 669 hp @ 35 psi SR powered 240sx here uses the ssautochrome manifold, I feel safe
plus the owner of that car is reinforcing this mani for me :D
