will anything other than oil starvation cause a turbo to seize up?
touchdown said:A buildup of solid chunks of oil that occur in the turbo when the engine is turned off while the turbo is still spinning fast (BB). Or if the oil in the system is heated higher than normal. It happens naturally too, just takes alot longer.
Stock SR turbos are water and oil cooled...mike s said:stock sr; Garret T25 I believe
