1 - 3 of 3 Posts
Ok so I have searched forever and ever and I cant seem to find ANYONE that completly knows the currect values of the MAF. I'm running an N62 MAF and I am having a stumbleing/hesitation problem with holding down the gas pedal slightly (like holding the RPMS at 1500) I'm adjusting the car to run good while idleing using nistune, however; when i give the car a little bit of gas it drops to a very rich condition and tries to die.
I'm wondering if my MAF is causing my car to stuble and almost die with slight throttle. I'm getting variable voltage readings while going through the throttle range, I'm just wondering what are some familiar numbers I should see?
Also is there a way to check resistence to determine the the failure of the MAF?
1 - 3 of 3 Posts
