I am looking for the specs of All Valve Prings that are made for the SR
Well at least the most
I have found 6 Diffrtent velve springs but only got some SPecs on 2 of them
Maybe this could ba another good tech thread for someone looking for SR Valve psrings
Here is What I have so far
Greddy - No Specs
Tomei (2 Types) A & B - A = single Spring / B = Dual Spring
HKS - No Specs
Toda - No Specs
Peak Performance - 250lbs
Ferrea - 255lbs
Apex'I - Dual Spring, Good To 8k rpm (I think Rhombus Tuning has taken them to 8750 rpm but w/ There built head IDK - But there head is only P&P)
If you guys have found and Springs or specs please post
Thanx
These are some specs I got from FreshAlloy
SPRING-----SPRING-----RATE @[email protected]
TYPE ------HEIGHT-----1.339-------1.200---------BIND
[email protected] REST-----(34mm)------(30.48mm)-----HEIGHT
Stock------1.975------110 lbs------147 lbs------1.082
Greddy-----1.910------120 lbs------159 lbs------1.045
HKS--------1.902------113 lbs------147 lbs------1.099
Comp-------1.902------134 lbs------168 lbs------0.960
Ferrea-----1.892------148 lbs------189 lbs------0.960
JUN ----------------Enthalpy will supply-----------------
Toda -----------------Need a sample----------------------
Tomei ----------------Need a sample----------------------
Apex -----------------Need a sample----------------------
Greddy - No Specs
HKS - No Specs
Toda - No Specs
Ferrea - 255lbs
Thanx
