Yes, valve springs can be too stiff. Too stiff of valve springs will cause increased valve seat wear and increased load. (friction is increased, and more power is used just to open the springs) The trick is finding a valve spring that isn't too stiff to cause excessive wear and friction, but at the same time not too loose to causing valve float.
