1 - 20 of 34 Posts
I wanted to start a thread of what people run in there cars as far as spark plugs oil ext...
gas
oil/oil filter
spark plugs and wires
trans fluid and dif fluid
coolant
what do you use and why have you had any problems with other brands.
rite now I'm using chevron 89 octane Castrol gtx and fram oil filters (but I will switch to k&n after I brake in my motor). Spark plugs rite now just autolite but will get NGK plugs and wires when I swap them next. trans fluid is walmart crap but swapping out when I do flush same with coolant.
Gas: 93 octane only.
Oil/Filter: Mobil 1 15w-50 / Fram oil filter
Spark plugs: NGK V-power
Wires: Generic part store wires right now, lol.
Trans/Diff fluid: Mystik 90w-140
Coolant: Straight water, flushed every couple weeks.
That's been my combo for about 4-5 years now. The only issue I had was when i changed my trans fluid to royal purple. I run 93 octane because my timing is bumped, and even when the timing is stock it runs like crap on anything less.
240-kid
Gas: 91 (The highest Offered here)
Oil/Filter: Mobil 1 Ext. Perf. 10w30 / K&N Gold Ffilter
Spark plugs: NGK Iridium's
Wires: Reg. Replacement's
Trans/Diff fluid: AMS Gl-4 75w90 (Lovely)
Coolant: Water w/ 10% Coolant
Looking to do Plugs and Wires the next Oil Change and use 10.2mm Wires
lets see
gas: 91
ngk iridium plugs
accel 10 mm wires
K&N filter
coolant with 50% water
is it a good i dea to run less coolant and more water like some of you are doing?
GnarKiller
Gas: 93/4 Sunoco baby
Oil/Filter: Royal Purple oil with Mobil One Filter
Spark plugs: NGK iridium
Wires: too cool for wires
Trans fluid: Royal Purple now, but Redline before (Redline > Royal Purple)
Coolant: Usually straight water.. sometimes add ins
Air filter: Greddy Airnix
240-kid
lets see
gas: 91
ngk iridium plugs
accel 10 mm wires
K&N filter
Depends on your climate in your area, google Anti-Freeze/Coolant to Water Ratio and it should give you a chart of percentages for diff. ambient temps
Fuel: 91 Octane
Oil: Royal Purple 5W-30
Oil Filter: NAPA stock replacement
Spark Plugs: NGK TR6
Spark Plug Wires: Stock
Trans Fluid: Still Stock Fluid
Diff Fluid: Still Stock Fluid
Coolant: Coolant/Water 50/50
I have yet to have a problem with anything I'm running.
Discussion Starter #8
Fuel: 91 Octane
pete you know you need to replace the fluid evry 50k or so
o shit wait you still got 30k b4 you hit 50,000 mils fucking brand new 7 yr old car you got a steal of a deal on her.
LOL, you stooge! She has 17,7XX miles on her now. I almost can't believe that I'm gonna upgrade the pistons and rods this winter!
sorry to revive an old thread, but do u guys recommend the ngk v-power or is it worth it to spend a little more on ngk iridiums?
gas: 91 octane
oil/oil filter: Mobile 1 Synthetic 5-30 and Napa Gold filter
spark plugs and wires: NGK plugs and NGK wires.
trans fluid and dif fluid: AMSOIL Syncromesh fluid
coolant: Gas Station 50/50 mix
240-kid
Update:
Oil/Filter: Mobil1 Turbo Diesel 5w40 w/ Mobil1 Filter
Me and two other ppl have noticed differences in the way our engine responds and feels. (2 S14's and 1 Colorado)
It may be a placebo thing but for me, it does feel more responsive, and love the fact that it has a High HTHS rating.
Fuel: 91 Octane
Oil: castrol syntec 10w40
Oil Filter: fram
Spark Plugs: NGK bk5regp
Spark Plug Wires: taylor brand 8.8mm
Trans Fluid: redline mt-90 gl-4 fluid
Diff Fluid: Still Stock Fluid, when i swap my z32 diff in i have some redline 75w90
my motor just clocked 206kmi yesterday :)
Update:
M1 15w-50 still has it beat tho.
High Temp / High Sheer Rating:
M1 15w-50 = 5.11
M1 5w-40 Turbo Diesel = 3.9
Mobil 1 Turbo Diesel Truck 5W-40
Actually I was just looking at Mobil site and seen 15w-50 was 4.5 HT/HS???
Mobil 1 15W-50
If only the parts stores around here carried RedLine. If I had 5w-50 in my area I would switch ASAP.
BTW, M1 High Millage 10w-40 has an HT/HS of 4.06
240-kid
Yeah.
The 5w40 is good enough for now. but once I start building up the motor I have and put that it. It's break-in then it's Redline 0w40 from there on...
Break-in I'm thinkin about just using GM Conventional 10w30 with Redline Break-In additive. Changes every 500miles (I get extra oil quick lol)
1 - 20 of 34 Posts
