some of you guys are really jumping around on this oil weight dill.. 20w-50, 15w-50?? Cars come with a manual for a reason. They tell you vital information about operating the vehical properly so your car lasts long, such the type of oil you should use. Without a doubt use sythetic or some type of synthetic blend whenver you can but people should take the weight of the oil more seriously. If i remember correctly, Nissan says 5w-30 for SR20DETs? or was it 10w30? multigrade oil is a wonderful thing but you have to learn how to use it properly.
10w-30, this meens 10 winter 30. The number represetns how thick the oil is. 10winter meens its 10 when the engine is cold, and 30 is when its at normal op temp. The reason why you use motor oil is to prevent metal to metal contact. Start up is what really kills you because you dont have oil flowing through your whole system. That is why you want a small number so the oil flows fast to the cams, and valves and all to coat it. If your using 20winter 50, that oil isn't as viscous as it was ment to be thus over long term, your cams and valve will wear out quicker via startup. 50 weight is kinda thick for normal use anways. Theres no harm tho. It keeps the metal nice and protected but being thicker, your lsowing your motor down. I'm not saying your gonna loose noticable HP and rev slower, but its just something to think about.
