1 - 4 of 4 Posts
hey can someone tell me what this looks like I did a swap and found these 2 wires by the ps pump that weren't connected to anything. I tried putting them together but it didnt fit so I thinkthey both go to something else. I traced one to the fuse box under the air box and it run there through a wire that goes by the ignition coil on the outside of the engine bay I included a pic of that wire. The other wire seems to be coming from the ps pump its a very short wire it felt like it was coming off of the ps pump
Power Steering pressure switch.
It tells the ECU to idle up the engine when you are turning the steering wheel while parked, to keep the extra load on the engine from stalling it...
Check the FSM Schematics..
I could tell you, but my car is 50 miles North West of my Current location ;)
1 - 4 of 4 Posts
