what solo2 class for swapped 240?
1.2K views 10 replies 7 participants last post by  240sxka24de-t
i hate reading through the classes, car is stock except for swap and some springs. thanks
no if you do any engine swap other than the EXACT same engine swap you are now in Street Mod. too bad, because if you run Novice or any pax factor affected class you are screwed. very very bad pax factor. sorry. and if you dont believe me buy a handbook and read for yourself.
zads said:
What rule in the SCCA rulebook is that?
Not that I'm saying you're wrong; I just dunno where to look for that rule.
The SCCA rulebook doesn't work by telling you what you can't do. It works, by telling you what you can do. There are no rules in any class below Street Mod that allow you to swap engines to an engine that was not offered in the car.
In Street Prepared, it does allow you to swap engines between cars that are listed on the same line. For instance, they put all of the 240sx on the same line in the rule book. Because of that, you can put a KA24DE into a 1990 240sx and still be legal for that class.
