top mounts are also known as INTER WARMERS cause they get hot cause of the engine heat, and hot air rises, right?
if u have it mounted right infront of the engine, but horizontally, you can make an air scoop/belt shield, that curves upwards after the radiator, and it will direct air right to the vmount. and the shoter piping does take about 500-1000 rpm off a spool.
it doesnt really take it off persay,, but it comes on harder and less time is taken since there is less tubing.. with high boost applications and light engine internals and a very good valvetrain.. you will notice gargantuan imporvements, simply because air is key, and if u get it faster, its better. injectors and fuel pumps are the last thing to do work in the whole process (other than sparkplugs) so if your cams are tuned right, and ur valves are lighter than leaves, then the air which is quickly forced in will find its place alot faster. and then the injectors will throw the needed amount of fuel in there to compensate for it, so you will gain a little more power down low.. and you wont experience LAG as much, which is the exact reason why it works how it does.
so thats basically it, if u have a good v moutn setup and it chills the intercooler correctly and efficiently, you will get less lag.
