1 - 4 of 4 Posts
Premium Member
Hey there, I have an opportunity to pick up a set of OEM rims off a 370z and hoping they will fit my 96 s14 project. Problem is they are across Canada from me and would like some help as I’m newer to this world. I have 18” on my car now but ones badly damaged and cracked. He gave me the specs
Front 18x8 43 offset
Rear 18x9 15 offset
Thank you for any insight.
Cheers
No direct experience with those sizes since I have 17x9 wheels that I got from 4wheelonline.
Nevertheless, my buddy is running 18x8 +20 and 18x9 +30. I will ask him about the tire size.
240-kid
They will fit. But it depends on how you want them to fit.
8+43 will fit the front ok depending on if you have shocks or coils and what size tire it's running.
Ideally in the front a 8+20 to +30 will fit almost anything without issue using a reasonable tire size.
With the 9+15 in the rear that can definitely fit. But again. Dependings on if you're lowered. What your camber is set to. Amd what size tire it's running.
On a completely stock 14 it'll fit. But it won't look right and may rub either the front shock or the rear fender lip or both.
1 - 4 of 4 Posts
