Where to get screw that holds the top of injectors?
958 Views 4 Replies 4 Participants Last post by  kosmo91se
Hey do any of you guys know the size of the screws holds the injector top in place?????????? or do you know where i can get some
1 - 5 of 5 Posts
any specialty hardware supplier(i.e. fastenal)... get an allen style that won't strip like the phillips head.
Got it, thanks guys . Question....will oil leak out of I remove the oil filter?? Im asking because i need to tighten up the oil adapter because it is causing a leak
removing the oil filter makes a little bit of a mess, its put in one of the worst spots ever i believe. I would drain it before taking it off to keep it at a minimum
1 - 5 of 5 Posts
