which pulley's, the asp's or the unorthodox's
1.1K views 13 replies 10 participants last post by  S14_TAT
Hi' I'm new and was wondering which pulley's to go with the asp's or the unorthodox's, someone help me!:help
Unorthodox now has a full pulley set...ASP still only has a crank pulley. The ASP pulley is heavier, cheaper, and of about the same quality as the Unorthodox. The ASP does not underdrive the A/C, whereas the Unorthodox does. I used to have an Unorthodox...but went the the ASP...because I wanted a new one for color...and wanted to save the money and get the ASP (that wasn't available when I first got the Unorthodox pulley). I sold the old Unorthodox pulley and got a new ASP and made a couple of bux.
Dennis
does the ASP gain the same as the Unorthodox set? i mean the ASP only has the crank pully while the Unorthodox has the whole pully set. I mean if they both gain the same power why spend more money on the whole set?
i don't think reducing the weight on the accesories really make that much of a difference. if you look at the size of the alternator, its soo small, and the fan pulley weights like 2lbs already, and the power steering pump doesn't really add load to the car unless goin below 15mph and turning the steering wheels. so that thing just basically free wheels, and the a/c pulley. hmmmm i'm not sure about that one, that thing is too tricky for me to take out. heh
