1 - 8 of 8 Posts
GnarKiller
I'm pretty sure the SR/KA clutch fan itself is interchangeable, but the shroud is NOT. The different upper radiator outlets between SR/KA will cause interference with the shroud kit. You could probably trim the shroud to make it work, but it will look off centered and won't line up properly with the fan (defeating some of its purpose).
I busted my clutch fan + fan shroud assembly. The OEM KA fan shroud (21476-40F00 - Shroud. (Upper) - Genuine Nissan Part) is about $50 more than the OEM SR fan shroud (https://www.enjukuracing.com/products/oem-fan-shroud-nissan-240sx-sr20.html). Will the SR fan shroud fit in my engine bay without retrofitting?
Consider a Mishimoto dual electric fans $192.00
or this one
GnarKiller
I personally love the stock clutch fan w/ shroud setup, but I used to run dual Altima fans and it held good temps. I'm not using it anymore so let me know if you are interested (fans/relay setup/wiring).
1 - 8 of 8 Posts
