1 - 10 of 10 Posts
· Registered
hey guys has anyone figured out a way to make your windshield wipers work with the rb25det swap? i read someone has had to hardwire his to make it work. any information would be helpful. thanks
· Registered
When you remove the f3 plug from the ka harness, you need to keep all the wires and plugs that run up to the wipers, but cut off all the ones that run to the ecu/motor. Then those are the wires that are spliced into for the swap. The ones to the wires remain untouched.
· Premium Member
um iirc on the s13 the wipers are on the chassis harness not on the efi harness unlike the s14.
should work fine as mine did when i had my rb20 in my s13 a while back.
· Registered
I didnt have to do anything involving that plug. When I got my car the KA and all its wiring was already out so something might be different, but i can't imagine you having to mess with it unless you already cut it off with the rest of the old harness.
· Registered
yeah, go to the links section on racebread.com and they have a "many good FSM downloads" link listed there. on that site you'll find an electronic version for sohc and dohc 240's. i d/led them but havent looked in them yet. hope they can help
1 - 10 of 10 Posts
