Universal, T3/T4 TURBO CHARGER T04E 0.50 A/R
3" Inlet Diameter
2" Outlet Diameter
Hybrid Journal Bearing
T3 Flange
Oil Cooling
450 HP Capable
Compressor Wheel 0.50 A/R Cold Side
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Turbiner Wheel 0.58 5-Bolt Standard Hot Side
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
25-35 PSI Peak Power Performance Output Capability
CNC Machined Flanges
________________________________________________________________________________________________________________________________________________________________
3" Inlet Diameter
2" Outlet Diameter
T3 Flange
Oil Cooling
450 HP Capable
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
T04E TURBOCHARGER
- 3" INLET DIAMETER
- 2" OUTLET
- WET FLOATING BEARINGS
- 1/8 NPT OIL INLET
- T3 / T4 FOOTPRINT OK
- .57 T COMPRESSOR WHEEL
- .50 A/R COMPRESSOR
- .63 A/R TURBINE
- .58 5 BOLT STANDARD HOT SIDE
TURBINE WHEEL:
EXDUCER:2.48"
MAYOR:2.89"
COMPRESSOR WHEEL:
EXDUCER: 2.07"
MAYOR:2.36"
EXDUCER:2.48"
MAYOR:2.89"
COMPRESSOR WHEEL:
EXDUCER: 2.07"
MAYOR:2.36"
