21 - 40 of 684 Posts
Discussion starter · #25 ·
nice
if need be we will see when its all in if ill need to but at some point i plan to change over to a map sensor so if i dont have to now ill change it up later then
parts where dropped off today for assembely should be done by wed next week then ill just need to pull my engine to get the last of the stuff ill need for a finished assembely
DONT GET THAT CATCO CAT!
I had it, its a piece of shit.
the top and bottom flange parts are tooo thin and just blow gaskets all the time. unless you were to weld it in then it would be fine.
and if you want power get a test pipe instead, the cat hurts your exhaust flow.
ive already had it on my car for over a year with no problems and i dont care for test pipes you dont get enough out of it to make it worth while
just ordered DeatschWerks 450cc injectors
mine on my s13 gave me nothing but leaking gasket problems at the center top or bottom :(
well in that case, keep doin what ur doin.
