i've been storing up parts for a few months now for this but didnt want to post until it was about to start moving so here it is.
the pile of parts
the block
my cams are hollow
ferrera 1mm oversized valves 5 angle valve job
intake port
exauhst port
ferrera springs and retainers
heres the parts list for the build
nismo clutch fork
c's short shifter
exedy stage 2 clutch kit
fidenza flywheel
port and polished head with 5 angle valve job work performed by cosworth
ferrera dual valve springs and retainers
kelford cams "broken looking for a replacement"
xessive manifold
hotshot intake
dc sports heaer
catco cat 3"
rsr ex mag
cometic head gasket
arp main head and rod bolts
weisco 10.5 to 1 pistons
eagle rods
unortodox crank pulley
sard fuel pressure regulator
walboro 255lph fuel pump
jwt cam gears
peak tranny mount
jgs engine mounts
thermal intake manifold gasket
4.4 final drive
DeatschWerks 450cc injectors
denso iridium sparkplugs
magnacor wires
crank scraper
greddy emanage ultimate
future going to add a aluminum driveshaft and itbs if im not satisfied
flow charts, build notes, and cam card
vid of it running
http://www.youtube.com/watch?v=cIzyeCVMzU4
the pile of parts
the block
my cams are hollow
intake port
exauhst port
nismo clutch fork
c's short shifter
fidenza flywheel
xessive manifold
hotshot intake
dc sports heaer
catco cat 3"
rsr ex mag
cometic head gasket
eagle rods
jwt cam gears
peak tranny mount
jgs engine mounts
4.4 final drive
magnacor wires
crank scraper
vid of it running
