2,761 - 2,775 of 2,775 Posts
Discussion starter · #2,761 ·
Great success
Just in time for the next things
As good as this is, needs to go for a bit. Luckily, there's a fitting replacement for the time being
Discussion starter · #2,762 ·
Enough of that.
Jebus
Better at least
Much better
Discussion starter · #2,763 · (Edited)
Well that's annoying, but something was bound to leak. Deal with that soon.
Finally looked into why my new turn signal stalk wasn't auto-cancelling. Little spring-loaded gear was stuck down on old grease, probably when I installed the new steering wheel. Simple pop up and we're good
More goodies starting to arrive
But first- Dyno Day
So on wastegate alone (after removing the stock boost control solenoid that can add some boost in higher gears); ran 195HP. (RPM reading may be a smidge low)
Low boost- 12.5ish, 225HP
High boost - 14.5, 250HP
Plenty enough for now.
Discussion starter · #2,764 ·
Tiny update - awesome titanium etched/anodized key and keychain from 47point9
Discussion starter · #2,765 ·
Parts continue to arrive, love you can still get most things new.
Missing fog surround finally installed; along with new clips and bolts
Naturally now the existing one looks like poop. Will have to grab a new one next order.
Discussion starter · #2,766 ·
Silvia of Theseus...continues
First world problems: Wrong fuse puller
Discussion starter · #2,767 ·
Still waiting on parts to arrive, but something arrived:
Neat for just plugging in to the consult port. Unpictured: It can also control fuel pump on/off. Need to figure out where to mount it now.
Tried to install a GKTech Torque Damper...but that won't work.
More little bits
Oof these need paint. Eventually.
EnglishTune makes a neat spare tire delete plate
While I'm in here... installed some M10 RivNuts in the existing chassis holes
Discussion starter · #2,768 ·
Noms.
Still waiting on another order before this can start going in.
Meanwhile - Silvia of Theseus.
Trying this position out. Not loving it. But we'll see.
Discussion starter · #2,769 ·
Wooo, 1.000km.
Those rivnuts finally get to be put to use
R34 GT-R Battery Tray fits pretty well, Cold-Region variant for the extra tray space.
New elbow. Nice to see the change from the previous gen I had to cast
Needed some new AN wrenches
Some toolbox stickers, maintenance bits, jack points
Silvia of Theseus
Treat 'yoself. Rize Ti Prop Rod
Discussion starter · #2,770 · (Edited)
One of my happy parts - Yashio Factory Titanium Strut Bar. Didn't know it'd be signed, but not complaining.
Battery getting closer. It technically clears upright, but just a PITA so. Will suck up the OCD issues and live with it sideways w/ an inverted label.
Now you see it
Now you don't
Bottom half of the manifold isn't even rusty yet. Weird seeing it clean
Ti downpipe with heat is neat
Up next:
Discussion starter · #2,771 ·
Progress is painful.
Buy 3mm allen socket.
Immediately breaks.
Fine. Double nut method works.
Until the studs are too long.
So now ordered new OEM studs and nuts. To go with the new Exhaust Manifold nuts. So much for using Titanium lol
That's going to be a problem. Onto a heat shield.
Need manifold in to do more testing.
I had to look around a little bit because I know I had seen a bolt-in heat shield for the ABS module; it looks like Weld and D-Max both make bolt in shields, or at least, used to. However, it does like the D-Max is available on eBay, but I can't open the link on this computer.
Discussion starter · #2,773 ·
Heh sadly the dmax fits like poop. Not even close. I got one off Buyee and was excited til I test fit it.
Weld always looked amazing. Would have loved one of those...
Discussion starter · #2,774 ·
More work, less pictures.
What a pain in the ass. ABS bracket can fk right off. Such a pain to get that all in there.
Petina is cool though.
I need to redo that factory breather, the bending touches the manifold and DEI is not rated for manifold temps lol. New radian line will fix that.
In other news: More goodies:
New HID headlights
YF Valve Cover. May run it. May just make it wall art.
Discussion starter · #2,775 ·
Well that didn't last long.
Jimmy O vid where they installed this at YF wasn't much help....this would not be a long term fix...
I hate it...but it works for now. Maybe have the bung moved on the intake when I get FMIC piping done.
