i have researched this and found no reason why people put 300zx fuel filters on their s13's can someone fill me in here
What don't you understand? A fuel filter is a fuel filter, nuff said.What you just said doesn't make sense, well in a way it does.
If your running an upgraded fuel pump, fuel rail, injectors, ECU, FPR, why the hell would you use a stock fuel filter in the first place? The stock 300ZX fuel pressure is 43.4psi (34psi on the KA's at idle, and 44 at WOT once the solenoid kicks on, bypassing the vac raising FP to 44psi)If you are running a high HP motor and have the fuel system to support it, you really think a stock fuel filter will be able to handle the extra flow, let alone the additional fuel pressure?
Any useful input? :S-A-Smack:calm down ladies no need to start pulling hair and clawing at eachother
Second response, I just left it alone and did not respond:Hi Rick,
Unfortunately, we do not have any support documents for this fuel filter.
1. They are physically larger, so with same amount of fuel flow vs a 240SX, - they will last longer (more material to plug up)
2. They are standard on 300ZX's which come stock with 300 hp. Many will push over 500 hp on the stock fuel system (stock hardlines, stock filter, upgraded injectors), so it must flow fairly well. We have made well over 400 whp on these filters with no starvation.
3. Limiting factor in the hp will be the feed lines of the 240SX, as the 3/16' hard lines can only flow so much fuel to feed so much energy (hp)
4. It's cheaper from Nissan vs the 240SX filter.
