I'm looking for a differential that is suitable for drifting and daily driving. Wanna help out? :beer2:
What is the difference between a 1, 1.5 way or 2 way Limited Slip Differential ( LSD ) ?
These numbers refer to the operation of the cams within the Limited slip differential. A 1 way diff only provides lock between the wheels whilst accelerating. In a 1.5 way diff, there is a degree of lock during braking, as well as under acceleration. The braking cam is half the size of the acceleration cam - hence the term 1.5 way. This provides a degree of improved balance during braking, but with less effect than a 2 way LSD.
In a 2 way LSD, the braking cam is the same size as the acceleration cam, providing more lock under braking. This provides the most stability and balance under braking, although it can induce some understeer in corners.
If you feel like your over steering let off the gas turn the wheel a little more then get back on the gas.
So welded dif
