Hello everyone, I'm looking for some outside opinions to a on going problem i have been having. that is keeping me from driving the car.
heres what im working with
redtop sr20det
HEAD:
engine harness (new)
HKS hg
HKS cams 264 272
arp studs
greddy springs
greddy ras
port and mild polish
3 angle valve job
custom valves
nismo 555cc injectors, used
nismo fpr, used
z32 maf (4 different ones all the same effect)
gti-r turbo
new O2 sensor
new temp sensor
Bottom end:
BRAND NEW EVERYTHING (besides crank)
ALL OEM parts.
management: ROM tuned
fresh ECU (off a swap) ecu has no dio light (odd no?)
nothing is half assed, i tryred to do everything PERFECTLY.
the car drove fine for the first 10 miles.
heres my problem i hope someone can shed some light on the subject
Key on ... no fuel pump sound...
start: car starts up right away, and runs idle a/f at 15.0, for the first 20sec.(feels like a misfre) and then the motor just gets PIG rich, 10.0 with in the next 30 sec.
car sounds like it has a misfire.. idle bouncing, FUEL dumping hardcore out the tailpipe. motor revs up fine, seems powerful and fast reving.
i pull the Rom tune off the ECU and the pump doesnt come on with the KEY, ON. car is put in "failsafe mode" The car seems to run a little better not dumping fuel as much and A/F is around 10.5 still sounds like a misfire, car will rev. normaly
pulled plugs: every single one looks the same, DRY, but fouled out BAD.
re did the CAS and put the motor in time. same.. problems..
motor compression is 150 ish across
i have been through a million plugs, maf's, coilpacks, CAS, O2's...
anyone have any thoughts?
i have an idea what it could be, i wana see if anyone thinks the same thing. before i waste anymore money...
Cya,
Chris
redtop sr20det
HEAD:
HKS hg
HKS cams 264 272
arp studs
greddy springs
greddy ras
3 angle valve job
custom valves
nismo fpr, used
gti-r turbo
new O2 sensor
new temp sensor
Bottom end:
ALL OEM parts.
Cya,
Chris
