Originally posted by RedNOSceli
the back is pretty self explanitory, pull off the old strut/spring, intall the sleave, reintstall.
Now for the front, its the same thing, but the sleave doesnt fit around the hexagon shaped cap. (somthingon, I dont remeber how many sides, a polygon of some sort). It very soft metal so I just took a file, filed down the edges of it and the sleave slides right down and rests on the stock perch...install, and ur down low...if you want to drop it onther inch of so, ud have to cut off the stock perch because the new coils perch will hit it, but its more then low enough 1/4 inch gap with them down as far as it will go without cutting off the stock perch....
I dont have a digi, but ill draw it up....
here my cheezy paint diagram, if ur mechanicly inclined, it should be good enough, ill take some pics with my buddies digi asap
also, the short set of springs go up in the front and the long ones go in the back...maby for the wrong year? I dont know....
