Cold lower rad hose, but good thermostat?
21K views 17 replies 9 participants last post by  stephnsons
Hey guys,
So, long story short: Car overheated one day and head gasket blew. No prior issues.
Replaced:
Head Gasket obviously
Water Pump
Heater hoses
Rad Hoses
Thermostat
Radiator (new Mishimoto 3")
Burped the system until the coolant level no longer dropped and I had good heat.
I started the car, went to work but the car started to overheat again. Heater on full blast and cooling fans did nothing.
Here's what I don't get.
New T-stat in in correctly and opens when I boil it.
I get good heat at the heater core
There is no exhaust coming out of the radiator.
When I start it and run it there is coolant flow to the radiator
But when I feel the bottom hose, it is cold. WTF?
Anyway, I am probably overlooking something simple, so I was wondering if any of you guys had any ideas. Thanks!
Alright, thermostat is out, and the lower rad hose is still cold.....???
I ran the car by driving it around for about 20 minutes and it didn't overheat. I even disabled the cooling fans to see if it would overheat but it didn't.
Anyway, I felt the lower hose, and the first 2-3 inches are warmish, and then it gets cold for the rest of the length. I can obviously squeeze the hose and with the bleeder screw off, coolant goes spewing out...
I know I am thinking blockage now, but I literally just flushed everything out and nothing was blocked. I ran a hose through the block and it flushed it nice and clean, and the radiator and hoses are brand new...?
Any ideas?
P.S. I get plenty of flow through the heater core and such, so I assume the water pump is working.
What's your ambient temp?
Stock KA?
You heater get warm?
You do realize that's what a bigger radiator is suppose to do right? Keep your coolant cool.
Take off the bottom hose and look inside?
Squeeze where it feels cold to see if anything is there?
I don't see what the problem is if your not overheating?
Current air temp is about 29 F, so, it's quite nippy. Snowed yesterday. Nothing like Hawaii, (born in Aiea).
Stock KA, 95,000 miles on it.
Heater gets slightly warm but not nearly as hot as it used to, I am afraid the sheer capacity of the radiator was keeping the car cool for the first 20 min.
So, I took it on a longer drive 30 min or so and warmer at 50 F, because I realized the top hose was pretty hot but the bottom was really cold and I just may not have heated it up enough the first time, and it started to overheat again. Felt the bottom hose and it's still cold but the top was very hot.
This is all without a t-stat... Kind of lost right now.
See that's why. You have a 3" Radiator on a Stock KA with Temps below 80. Even with how warm it is here I sometimes go back into warm up/high idle cause the coolants cooling off too much.
Honestly if nothing's going wrong besides it being cold I don't see any problem.
But I would advise you put a new thermostat or atleast a good one in to help get the engine up to temp.
Well that's the problem, it's overheating right now. I tried burping the system a few more times, but no air came out. Seems like there's no flow to the radiator, it's really strange.
I am going to yank the intake off and recheck the heater hoses to see if one has collapsed for something.
Is it possible for a collapsed heater hose to stop flow to the radiator? And is it possible the radiator cap is somehow overpressurizing the system? THe cap is really really tough to screw and unscrew.
BTW, thanks for the help.
The bottom hose is always gonna be cold or coldish. The ka's have a reverse flow system, coolant goes in from the bottom and out the top.
Ummm wut?no. hot coolant from the engine goes into the radiator from the top and gets cooled then the cooled coolant goes out the bottom hose to gather heat again from the engine
I know it's overheating because the temp gauge goes to 3/4 of the way up before I pull over (I know they are weighted gauges), and the coolant starts to boil.
Takes maybe 15-20 min of normal driving to get hot, and the heater doesn't seems to make it drop any more than it heats up. I crank it to "4" and it still rises.
Not sure if this will help you much but I had an 80s camero. Put a racing rad in it. Bigger core and such. In the colder temps I had to run without a T-stat. One side was to cold and the other was hardly at temp for it to open. So it mostly seemed that it was over heating. In the summer over 85 constant temp I would run a T-stat so what's in the rad would have a chance to cool.
My KA I have a duel core koyo and I haven't had any issues without a T-stat winter or summer. I also have never tried with one in. I just stuck one in to see what happens. But I'm sure I'll pull it out soon.
i have the same problem with my ka, it was overheating so i flushed, new water pump, thermostat, ext. with no thermostat the top hose is hot and bottom is cold, i can watch the coolant flow from bottom to top, but the thermostat housing is on the botom hose. so how can the thermostat open its on the wrong hose?
