DIY: 4 step rattle can paint job
7.9K views 30 replies 23 participants last post by  ballr858
as most of you probably have a pretty good idea on what to do, this is for the people who dont.
What you will need
about 3.5 hours
8 Cans of paint of your choice. (we used rustoleum satin black)
a Friend (can do by yourself but eaiser with 2 people)
2 Can-Gun attachments, get at pep boys or similar.
some sort of degreaser to get rid of your current wax.
medium grit sand paper, 2 sheets should do.
masking/blue painters tape
News paper or something similar.
Step one
take the degreaser and go over your car with it to get the current bit of wax thats on the car.
then wash your car to clean it.
Step two
take the sand paper, cut the sheet in half and start sanding. use a block for the large areas if you want, but just use it in your hand for smaller areas. rough the whole car up decently for the paint to stick.
Step 3
mask off the car. windshiled, mirrors, tailights, turn signals, license plate lights, wheels, sunroof (if applies) and headlights if you dont have pop-ups.
one tip - mask off the trim to outline the area you will be working on. this will make it much easier when you go to cover the windows, your taping doesnt have to be perfect.
Step 4
Paint! now this is the hardest part. make sure you get the Can-Gun, it makes the job 100 time easier to do.
Hold the can about 6-8 inches away from the body and spray in even long strokes. DO NOT just pull the trigger and hold it, or do it too sparatically. pull the trigger, count 1 mississippi and let go. keep doing that over and over until you have the car covered.
once you have the first coat on, you should have used about 4 cans, let it sit for about an hour, then go back and spray the second coat on lightly.
for the second coat hold the can about 12 inches away and go in long even strokes like on the first coat. the object of the second coat is to just cover the first, and not fill anything else in really.
heres the time frame that it should be broken into
Degrease and wash - 40 mins
Sand - 20 mins
Mask - 30 mins
First coat - 35 mins
Drying - 1 hour
Second coat - 25 mins
3.5 hours total.
paint isnt totally dry in these pics, and the car was gold.
looks like you did a real nice job. a recomendationthough fill up a 5 gallon bucket with hot water and put your spray cans in it. This will raise the pressure inside the can and create a finer mist when sprayed and you wont get the stripes like you see on the hood pics. I did this kind of job before and ended up re doing it using the hot water technique. it turned out 10 times better.
looks like a pretty good job , but even tho the paint isnt dry yet , it still looks like when it does dry your going to have to give it another coat... and with some primer you would have gotten a darker coat
yea, but my bro isnt too worried about it. within the next month he has over fenders coming (painting again) and wheels. then in the next year he's getting a kit, carbon hood, trunk, and gonna get a real paintjob. this is temporary, hes getting 2 new doors and needs to replace the lower tailight panel so it just sorta a temp paint job to make everything one color.
i did the 99 cent spray cans on my car and since there no sun protection in that kind of paint it would fade to gray. i had to paint the car once a year. i have now used duplacolor on my hood ( took 2 cans) looks alot better. i dont think 8 cans will do it i use more like 10-12 cans of the cheap shit. its seams like the dupla color dont go as far.
clear will give you a clear coat. and it will help kep the fade off. it will also make it alot easier to clean and wash, but it will not make it more reflective like a real paint job.
looks like a good rattle can job thou, not to many stripes.
I am in the process of doing the rustoeum/tremclad $50 paint job. its better than rattle can, but not as good as maaco. Its coming out pretty nice though.
