do i need a new window motor??
1.2K views 6 replies 5 participants last post by  95s14bomb
been having problems with my driver window...seems to only want to go down n not back up unless i tap on it with something...any suggestions are appreciated thanks
Doesn't actually mean the motor is bad, but unfortunately in some cases they are.
let me help you. I had the same situation happen to me 2 years ago.
#1
my window would go down but not up. I would have to tap the door panel to hit the insides. to get it to work. I found out it was a loose connection at the window amp.
make some bends and have pressure at the window amp connection, try every angle to see if that helps.
#2
if not just replace the window amp, its going. (it happen to me yesterday, just replaced it and it works good as new. if your window has been going up and down slowly lately more than usual then you know its the amp thats going)
