i know this has been discussed. i have a bit of a different question.
i want to wire up the altima fans to my s13.
my plan is to use the factory ac fan wire to switch on 2 relays to turn the fans on high. the question is if i set up the low speed to come on with the ignition, can a 5 pole relay for the high speed trigger the low speed cut off somehow? i know how to hook up the high side to just work, i just wanted to have the low somewhat functional in a temporary manner to avoid issues.
i dont want to burn out the motors, and i understand that if both sets of wires are energized then you get a medium speed instead of the full high.
i am going to add a thermoswitch at some point to control the low speed, but i am just trying to get my car going without the a/c causing it to overheat at a stoplight. and i do not want to add a fan controller, i am trying to tuck and hide wiring to make it look stock and operate easily while not adding much under the hood. i have a 3 relay mount with relays that i got from an eclipse in the junkyard that i am going to mount next to the radiator, in the location where the charcoal canister was originally mounted.
