I got a 92Se Coupe..How do ya remove the spoiler? Let me know!
Tony
Tony
did you just gob bondo in the holes?S13driftaz said:i used bondo for my holes.![]()
that post was extremely uselss :smacked49TiNyT said:If your taking your wing off to put a bigger one on... then you should just mount your new wing on top of your stock one....double stacks are sweet! your car will have great downforce then! because that is the point in putting a wing on right? now when your cruising at 200mph to work your car wont lift of the ground.....god im retarded
:rotflmaoTiNyT said:If your taking your wing off to put a bigger one on... then you should just mount your new wing on top of your stock one....double stacks are sweet! your car will have great downforce then! because that is the point in putting a wing on right? now when your cruising at 200mph to work your car wont lift of the ground.....god im retarded
