How to perform diagnostics check?
1.5K views 12 replies 8 participants last post by  Shwag
I was wondering if anyone knows the procedure to do a diagnostics check on the S13? My check engine light turns on intermittently, and has no effect on how the car runs or on gas mileage (22-25MPG consistantly). I have taken the car to a shop, and they said a code reader is not required to check the ECU for engine codes.
I need to get this problem sorted out because the check engine light has caused me to fail smog twice already even though everything else checked out perfectly.
Code 32, EGR. 3 red flashes, 2 green.
Any reccomendations for how to fix the problem? I'm guessing to check/replace the EGR valve, but I'd really rather not have to take off the intake manifold and clean out the EGR shit. Atleast if I do I'll have an excuse to bring out the dremel and match some ports. :)
Too bad my car is a 1990 as stated in my sig. and the OBDI system didn't become standard until 1991. Problem solved either way.
