OK, 89 240SX KA24E W/ M/T -
PROBLEM: WON'T START, JUST CLICKS. WILL PUSH START FINE.
I KNOW ALOT OF PEEPS HAVE ASKED ABOUT THIS IN OTHER POSTS, BUT THE REPLYS ALL SUGGEST WHAT I'VE ALREADY TRIED.
BATTERY - GOOD(FULLY CHARGED AND TESTED)
STARTER - REPLACED WITH TESTED STARTER THAT SPINS LIKE A CHAMP (good thing I have small hands or i'd still be cussin' that top bolt while managing 1/16 of a turn from each attempt!!!!)
This car was GRACIOUSLY given to me 4 months ago by a neighbor who was moving out of state and only needed one car to get there. It had sat in his back yard for 6 or 7 months prior to this, but when I turned the key she fired right up and was driving problem free until about 2 weeks ago. 2 fuses had a meltdown in the fuse box inside. They were for my parking/brake lights and turn signals. Fixed. Then my clutch started acting anal-retentive about going into and coming out of R & 2nd sometimes 3rd. Seemed like I had to slam the clutch pedal to make it work. 5 days ago I spoke nicely to her, and turned the key but CLICK CLICK CLICK was all she would say back. So I tried the obvious first (battery connections, cables, fuses) before deciding to wrestle with the starter and replaced it. Again.....CLICK CLICK CLICK. Thought perhaps it could be the clutch interlock doohicky or the pad on the clutch pedal that pushes the doohicky, inspected and they both looked and worked fine, but still no go. Headlights do not dim when trying to start, radio, dash and dome lights also do not dim. That makes me think it could be a relay or a switch probably hidden in plain view that won't allow the starter to do anything but CLICK CLICK CLICK!!!!:crazyrant Because I am working on this by myself, I can't actually tell if the clicks are from the starter or from somewhere else in that area (can't run fast enuff between drivers seat and engine compatment to tell), but I do know that it's from the general starter area. Should I try to bypass the Interlock relay (next to battery) or is there sumthin else I should try first?????:12dunno
ANY ideas and/or advice would be GREATLY appreciated.
Thanks~
Thanks~
