Kill Switch
4 reading
9.7K views 31 replies 7 participants last post by  fakingdeath
I am looking to install a kill switch but i am not sure on what wire to cut or where. Any help is appreciated this is being done for security.
If your going to do a kill switch make it unique. Dont go to a forum and do this: The correct way to make a Fuel pump Cut-off switch!! Tech Article: 240SX Forum / 180SX Forum / Silvia Forum: Nissan Forums / Infiniti Forums - NICOclub
because anyone wanting to take a 240 can easily find this info just as fast/easy as you did. I would start going over the wiring diagram yourself and make a kill switch that only you alone know about to make it that much more difficult for anyone trying to jack it.
Well whats your reasoning behind putting a kill switch? If its just to cut the fuel to the motor run it off the fuel pump. If its to cut power to kill the motor run it off the coil pack like fonix36 said... never understood putting a killswitch unless its a all out drag car running alcohol or you have a secondary fuel pump.
oh yea i didnt make that specific.
the coil pack on a single cam is located on the drivers side its connected to the distributor, if you dont know where it is i dont think you should be messing with your ignition system
