make your own fan control from parts you may already have.
7.8K views 41 replies 25 participants last post by  blackoutb15
thought this would be a good write up as i still see some people suggesting controlling an electric fan with a freaking toggle switch. i did this with all parts i already had, except for the fuse holder. i'm not gonna hook it up unfused. it will turn on at @205* and off at @185*, well within factory operating temps.
on the 89-90 240sx's, there's a switch that's used as an "emergency" fan switch, when it senses the temps of the water coming OUT of the radiator are over 200, it switches on the fan that usually only operates with the A/C. the later sx's also had the fan, but not the same switch.
i did a DE swap into my 90, and i used the radiator from the 92 donor car, which already had this fan on it, so i ditched my mechanical fan, and went looking for a fan controller. one problem. i'm a cheap ass. i wasn't about to drop $40+ on something i could make myself. ok, on to it.
my car already had this, but as it's not used on the DE swap, i made use of it.
i put it in the hose with the switch down, so that if there's an air bubble, the switch will still get a correct reading.
no explanation needed here hopefully
I like trying to solder. i suck at it, but i get the job done. i also don't like crimp butt connectors. they cost more, and as i already stated, i'm a cheap ass. the connections are also more likely to corrode, and where i live, the salt isn't on the road, it's in the air. if you are as bad at soldering as i am, you may end up with something like this
the wire that i added is 12ga. to match the factory size. 12ga. is big enough to run the fan without need for a relay.
the rest is pretty much duhhhh,,,,
hook it all up.
now you don't have to remember to turn your fan on or off. don't give me that B.S. about cool down at the track,,,this will continue to run even with the key off until the coolant in the hose is lower than the temp your thermostat will open anyways.
total cost, about 2cents for solder, and $3 for an inline fuse holder.
thanks abunch! just intalled my ford temp electrical fan. im using a switch for the low fan speed, and im giong to use your write up for the highest fan speed!
i have a simple question before i do this. i bought my current 240sx about a year ago and i noticed the ac belt wasn't attached. so when i installed my fan, i took out all the ac equipment that is located in the engine bay. would there be any problems problems disconnecting the harness connector from the lower radiator hose thermo, even without running ac??
i believe they are on seperate circuits. i still have the pusher fan in front that came with the SOHC, haven't hooked up all the a/c stuff yet, so i'll find out if it still functions normally later. the main thing i wanted was to ditch the mechanical fan, and make use of the free puller fan from the DE donor.
you can also reverse the wiring in order to make a push -> puller and puller -> pusher, for instance instead of grounding the black cable, use that cable to get the power and use the positive cable on the fan as the ground. i'll do this myself and see what happens.
the way im wiring this is exactly like this:
positive -> one end of sensor plug
other end of sensor plug -> highest fan setting wire
the fan is already grounded by itself so no need to add another ground
nice right up i did this to an never even thought about doin a right up hell i never think about the fan any more
i took all my ac out compresser and all and the fan still kicks on so ur good to go
i didnt think about installing it with the sensor on the bottom hmmm i think ima go flip it over
thanks u just answered a problem I had with my sr that had nothing to do with this write up lol. thank alot
huh?
BTW, it works perfectly, started the car up and let it sit. the gauge never got over half, and when the fan finally kicked on, it scared the shit out of me cause i was leaned over screwing with something on the exhaust. it's been sitting for a while, and the fan threw leaves at me.
one of those times you look around to make sure noone saw you crap your pants.
anyways, after running MAYBE 20 seconds, it cut off. i wanted to make sure it was the switch functioning and not just something blown, so i let it run some more. sure enough, it switched on again shortly after. it doesn't run long. on the third cycle, i waited just until it cut on, then i turned off the car. it continued to run 20-30 seconds, then cut off.
like i said, works perfectly.
wired my ford taurus fan this way. only thing is it is still on the lower radiator hose, i have a ka24e. car is running a little over half and fan only comes on for 2 seconds (no shit, cause its measuring the coolant FROM the radiator) but it doesnt seem like too much of a problem. you guys know how much warmer my car will be running? i'm hoping a week of driving till i have time to fix it wont damage anything.
well i did it and it seems to work. Dont know of the exact temperatures because i have the sucky stock gauge but it actually seems lower than before...might just be me though. When I drive and flip the manual switch for the fans, the car like, bogs for a second and then picks up again...weird. But when I at a stoplight for a while, the fans turn on and the rpms drop, then goes back up. I'll see what i can do to fix this. Oh yea, i wired it up to altima fans, these things blow hard! I can feel the air being sucked in when i put my hand behind my intercooler!
So this works for the Higher speed?? Or the Lower??
Sorry, I have read so many "S13 electric fan installs", my head hurts, and NO ONE can give a decent SOHC write up.
So I can do this with my ford taurus fan?? Do I hook the low speed up to the AC fan wire?? and this is for the high speed(like at the track it might come on?).
Or is this the low speed?? (cause you are using a 30 AMP fuse?)
And I just need to hit the junk yard for a extra "emergency fan switch"??
is the "emergency fan switch"s 205 to hot for a turning on point??
Sorry, but thier is so many rediculous writeups out thier, its now confusing.
you can wire this for either low or fan speeds. i would recommend having the higher fan speed switched on with the sensor and the lower speed fan either wired to a switch or wired to an accessory, so it turns on at start up.
#25 · (Edited)
it has worked fine ever since i got the car on the road. i removed the mechanical fan completely, and i'm ONLY running the s13 electric fan that comes on the 91-94. the fan in front of the condensor is hooked through a relay to my a/c compressor, and i've had no problems with heat,,,the temp stays rock solid just a tick under halfway up the gauge. all this in 98*, 99% humidity south mississippi heat. so hot i had 2 soda cans explode inside the car.
DALAZ, yes you can use it with an aftermarket fan.
#29 ·
has anyone had heat issues with the wiring? i noticed my wires are damn hot and im afraid of burning out the sensor.... it burned out two of my switches!
