Status
Not open for further replies.
My RB20 Swap Has Begun: Pics from Start to Finish (no 56k)
37K views 122 replies 44 participants last post by  KAT0
UPDATED(9/5/05) My RB20 Swap Has Begun: Pics from Start to Finish (no 56k)
I figured I'd post pics of the swap progress so far. I plan on doing a full pictorial writeup from start to finish on swapping the RB20.
I bought the swap car this weekend on Saturday from a really nice couple in Brandon, FL. Its a non-wrecked, clean title, 2 owner 1990 5spd beauty that I picked up for $450 because the KA needed over $1000 in repairs and wasn't justifiable for repair.
On Sunday, I woke up at 9am and began removing the motor and trans. It took me till about 7:00pm to finally have it removed. But I had 3 meal breaks, a break to go borrow the hoist, and drink breaks. So subtract about 1-1.5 hours for that and this being the 2nd KA pull, and 4th motor pull for me made it quicker. NO POWER TOOLS USED, so time could be saved with those.
I finished up the day by pressure washing the engine bay, wheel wells, and complete underside of the car.
Next step for me is to acquire the RB20 motorset and prep the car for install. Prepping will include installing the walbro pump, rb20 crossmember (or mounts, havent decided), and removing the rest of the power steering lines and a/c equipment.
I will update accordingly and provide as many pics as possible of the process.
_________________________________________________________________
Day 1 and 2: Purchase and pickup of 240sx, Engine Removal, Cleaning
Before any removal:
Airbox, Intake, Battery, Spark wires, and componets bolted to shock tower, removed:
Fan shroud, radiator, removed and fuel lines disconnected (depressurize before by opening fuel cap):
Mechanical fan, fan clutch, exhaust manifold, branch wiring, harness, power steering resevoir, A/C lines, throttle cable, cruise cable, brake booster hose, and rear ground removed:
Chain was hooked to each mount and hooked to the host in the middle, angle is steep but it has worked this great this way, every time with a 240. Use a jack to support the tranny while the whole unit is being hoisted upwards. CAREFUL, watch to see that you are not hitting power steering lines and that wires are clear and not getting pinched off:
You will have to lift the tranny up and over the front of the car while a buddy helps move the hoist back:
Engine bay before cleaning:
New 240 of left, old on right. The red one was my failed Rb25 project. I swapped a SR20 into it for a friend:
Another pic of the old 240, quite a clean example as well:
Drivetrain contents stowed away until I trash the engine, make sure to keep the wiring harness to use for extra wire and the lower tranny harness needs to be kept for the Rb20 swap:
Engine bay after cleaning. I coverered the fuel lines, a/c firewall sockets, heater firewall sockers and electrical connectors with zip lock bags and duck taped closed to protect from water. I used Simple Green degreaser and let it settle for a minute before pressure washing the bay. I used a spread spray on teh pressure washer and kept a 12-24 inch distance from the paint so that I wouldnt damamge it. You can hit the crossemember and frame rails hard to get the gunk off:
when i saw the front pic when it was still wet and shit i was all holy shit that is clean.
some how i got my motor out in like 3 hours, but then again the only thing attached ti it was rad, intahe , exhasut, driveshaft and wiring harness so that makes it easier... as wel as it only beingin therhe for 3 mothns lol:(
but ya good luck on the swap! and its hard to tell how clean that engien bay is becuase its a weird light kinda night time...but if you look on the wheel well part you cna see it shinig lol.
sr240dett3 said:
why are there 2 threads for the same thing.
one in the S13 threads, and one in th RB threads
you only need one.
Because, this thread was intended on being a write up and step by step on the RB20 install. Purchasing the car itself happened to be a part of the process and was why it was mentioned here.
The other thread was intended for view by other s13 owners, seeing how RB S13's are quite few compared to S13 SR20, KA-T, CA18. I was just more or less showing my 240.
:12dunno
UPDATE:
Day 3: Picked up motor from JHOT in Augusta, brought it home, and unloaded it.
At JHOT: Removed downpipe and auto tranny before loading into the truck.
Loading motor into the truck.
Strapped the motor down.
Arrived at home.
Unloading the motor.
Rb20 dp, intercooler, to be reused.
I was pissed when I discovered the turbo coolant line had been cut. Thats ok, I fixed it with some fuel line and made a little heat shield to protect the rubber portion from turbine heat.
Torque converter and flex plate still attached.
Removed the torque converter and flexplate. Ready for flywheel/clutch.
Removed A/C and Power Steering.
The lonely, motorless 240 awaiting its new heart.
lookin good man, but make sure to put a manual tranny pilot bearing in the crank else bad things will happen.
jhot is awesome i got my engine from them waaay waaaay back.
Thanks man. Yeah, I've got the Spec Stage 1 clutch kit on its way. It should have the 300zx N/A pilot bearing included. I've got a friend with a Mazda SST pilot bearing removal tool so that might make quick work of the auto bushing.
Was your motor originally an auto?
nope my motor was a full fleged manual when i got the clip.
i was just remembering back to when one of my friends did his auto to manual rb20 swap and he forgot to change the pilot bushing and it made horrible noises.
ya gonna be at NICO's meet at nopi this year? im gonna try to make it down there and meet some of you guys......
I'm gone to try to be at the Nopi NICO meet. My parents live about 10min from ATL motor speedway, so I've got a place to stay for sure.
This will be the 2nd time I try to get an RB powered car to Nopi and hopefully this time i'll suceed.
modestmouse/s14-240: Did you guys use the N/A 300zx pilot? Did it work fine?
Also what did you use to cut it out? On my last Rb, it was a copper material so I used a narrow chisel and broke it into small pieces for removal.
The 300zx pilot bushing should work. I used a 240sx pilot bushing because I had to get a different clutch kit...different story. It worked fine though, no weird noises. All of the Nissan pilot bushings should be the same so you can use either.
I don't think the bushing you're talking about cutting out is the same. It definately is not copper (must have been your old pilot). I'll include a pic of the bushing if you don't mind. I used a chisel and had little luck. I ended up messing it up so bad that I had to grind it down until the pilot bushing could fit past it (it's remnants are still there). I tried everything before this. I borrowed a friends awesome slidehammer and it didn't work either. The problem that prevents a slidehammer from working here is the lack of a lip on the back of the bushing for it to lock into.
The way to get this thing out is to get a rod machined to the exact inner diameter of this bushing (know it sounds excessive) and fill the chamber with grease. Really pack it in. Then take a big ol' hammer and give it a whack. The grease will force this bushing out cleanly and without scarring the end of your crank. My bushing will be in the end of the crankshaft forever. There is no way to take it out short of taking it to a machine shop. :tears
Good luck.
Thanks for the info man. I'm actually pretty freaked out about the pilot bushing. Maybe yours was a fluke, or at least I hope so. On my Rb25 the pilot was copper or copper mix and I just used a chisel to break it up.
Yeah Carl's friend was me. That was really bad idea. I didn't replace the old one with the manual bushing that came with my clutch (dumbass). It made horrible noises like my car was gonna drop its tranny and blow the clutch. It made horrible clutch slip noises. Anyway with me having to pull the motor once because I had to put the tranny and motor on as one piece and having to pull it again to replace that bushing. I have had my engine out many times. Now everything is all good and well in a sense. Currently I'm dealing with replacing my water pump while the engine is in the car this should be fun. I should have replaced it and the timing belt before I installed it. Now I get to pay for it with a ticking water pump that is about to go and not cooling my engine. Do it right or pay the price. For flywheel bolts I had to use my KA flywheel bolts and they fit fine but the auto ones cannot be used. Their heads are freakin huge.
~ANDREW~
Oh yeah to get that pilot out I took a pair of vice grips and clamped wicked hard on the end sticking out. Then I took a hammer to that or was it a 3lb sledge. Hummm... I'm a bit violent but it comes out without too much trouble.
modestmouse said:
You know there are two different bushings right? I already told you that the copper bushing you're talking about was your old pilot. Most pilots are of a copper color. The thing in my pictures IS NOT the pilot bushing. It's what I had to cut/grind out.
So what exactly is this thing that I'll be looking for? I'm getting confused now because I thought it was the auto pilot bushing but you say it is something else?
Thanks for the help! :thumbsup
It's on the motor side where the shaft of the tranny goes into the engine. Its the bearing that surrounds that shaft. Just put the NA 300z one in and you are good to go.
~ANDREW~
~ANDREW~
So you are saying, remove the auto pilot bushing and put the n/a 300z in and not worry about the other bushing that modestmouse is talking about?
I don't know what the heck modest mouse is talking about. I know I replaced the thrust bearing and pilot bushing that is in the motor where the tranny shaft goes. Replace that and put the 300zx clutch on and your good to go. None others need replacing.
Status
