Oil Plug Gasket
627 views 3 replies 3 participants last post by  AutumnTactics
Is there a gasket on the oil drain plug? When I changed my oil, there was a very very thin ring that i believed came off of the drain plug. I decided not to use it and threw it away because it was broken. Now it seems like my oil is leaking through the drain plug.
thanks. i'll look at the dealer for it.
i didn't know if the metal washer/gasket was from the drain plug or not cause the drain plug fell so after the oil finish draining, i looked and there was a metal ring and the ring seemed broken. so i decided not to use it.
