Ok I'm striping the Turbo Max and installing turbo in s13-start a step by step?
I'm going to set the Max back to stock after all that work. I just don't feel like buying all the turbo stuff again. I'm not looking to make crazy power I just want it to work right and be reliable for a while.
So here's what I have.
92 Ka-de
T3/60-1
38mm tial with 10lb spring
Safc2
Cartech like FMU
370cc inj.
Walbro 255 might not fit from the Max.
I just found about $1300 and they haven't been picked up by my wifes radar.
What I think I'll need:
T3 flange manifold ($400)
Do they make smaller springs for the 38mm tial?
some piping I cant use from the Max
Questions:
*The stinking s13 maf. Will the SAFC be able to control it?
the MAF hack doesn't seem to work with s13 MAF so will I be able to use the
370 inj.?
* MAF position. Some put it on the charged and others on the intake side.
I wouldn't mind having the BOV pftsssh. Does any one have the KA running without the recirc. hose?
*Is there a step by step like the SR install? I couldn't find it. If not should we start one. Starting with a basic setup and moving into the more advanced setup. (with pix would be nice)
* should I just spend the money and get the Jim Wolf Ecu and add the SAFC to fine tune? I know they say you shouldn't but would it work?
* are there vacuum hints on what to do with vacuum lines?
I know that's a lot of questions but a nice FAQ KAt step by step would be nice.
I did some searching and found a lot of debates with some of the options.
I'll take pix of everything I do if someone is willing to do the technical writeup?
92 Ka-de
T3/60-1
Safc2
Cartech like FMU
370cc inj.
Questions:
370 inj.?
