power door locks??
965 views 16 replies 6 participants last post by  SILVAWNABE
my power door's stopped working...yes i have replaced the door lock timer under the dash, and the magneto's in the door's, anybody know what else might be the problem?
does anybody know if there is a part of the factory harness separate from the door lock harness's that goes in to the main harness? I swapped rb20 and there is a small white harness maybe "5 or 4 pin" up behind the ecu that isnt plugged in because the rb harness is different
My passenger door is fucked, i have to unlock it from the inside, the key wont even turn once its in the hole, you have to hold the handle up on the outside and lock it and hold the handle until the doors closed and let go and its locked. And my drivers door, you need to lock it from the outside. Its all screwed. Anyone know why?
this is a very common problem on the s13. the two 240s i own does not do this though. maybe you should take off your door panel and check out all the linkages and stuff.
ok the "door lock timer" relay under the dash has no power, problem number one, if any body has this door lock timer relay under there dash behind the ecu could you test the harness with a voltmeter with the car off to see if there are suppose to be any voltages coming through
