Well just as the topic says when i am driving and if I let my foot off the gas too soon my car will stall and when i come to a stop if i let off too fast it'll stall. Anything that you guys know that can point me in the correct direcion??
Mine did something simaliar where it would shut off as well. but i believe its due to the lack of air going into the engine in between shifts and when ever the throttle is released. i will be correcting this when i install my stand alone.
Mine would cut off and it would be a pain to get back started. but i also believe thats due to another problem.
Check for vac leaks, your timing , tps, icv, and for giggles & shits the wiring for your maf. I had the same issue on an RB25det and found that the #6 fuel rail to manifold grommet was trashed and another RB w/ a leak the icv hose creating a vac leak which = stalling. Those vac leaks on a boosted motor will get you every time.
Yea differently check all gaskets/seals/couplers etc
Bust honestly i think it might be due to the Blow off valve....
I had that problem with my SR as well when i put a atmospheric bov
Related Threads
Nissan 240SX Forums
posts
1.6M
members
94K
Since
2002
