think of it as a relay/fuse
If there is a problem between your ecu and coil packs your ignitor is supposed to be what blows. You ecu sends a signal to your ignitor telling it to send a signal to your coil to ground which causes your coil to send a spark to your plug.
With that said, there is no benefit to plain out swapping to a different chip. I do however wish there was a way to know if one was more resistant to longer dwell settings. This could lead to a performance increase on tunable ecus/stand alones.
