Cause i'm still using my stock system and it's very annoying(automatic shoulder belt) and the lap belt is raised 3-4 inches on the inside part where you click it in. Any suggestions on a solution? Anyone run Takata's with these seats??? HELP!!!
What kind of safety belts do most people use with their R32 Seats?
run those takatas throughthe opening in the seat and bolt the bottom 2 parts of the belt to the seat mounting bolts or if you really want to , you can take out your rear seats and mount it there.. get creative
I did swap my stock clicker for the R32 one but the R32 was much shorter than my stock one so now it sticks up above my waist and looks semi retarded :-/
can't you rotate that clicker some...it looks as though you made it vertical when it should sit further down...that is probably why it up 4" over your waist.
another thing, You now how only 3/4 bolts match up and how the floor is double walled, well I drilled throught it and just used a narly bolt/washer combo. how bad is this solution?
he is talking about the mounting of the skyline seat. Only 3 out of the 4 bolts will bolt on to hold the seat down. the last one which is the rear outer bolt is like an inch off....what I did was use the existing hole but put a bigger washer in to clamp down the rail...better than not having it held down.
extend the bracket by welding on or bolting on an extension then use the original bolt through a hole in the extension. I just used a piece of flat iron
i am curious, can you take the clickers off the s13 seats and use them? i never tried it since i never really used the lap belts. As for the bolts...if it holds it down and secures it from moving, there shouldn't be a problem...i would use a bigger bolt that comes from underneath the car.
Yeah, this is the front on the driver side, the bracket got bent straight during shipping so I just went with it If anything I feel it is a stronger mounting postion.
either way you have to drill a complete new hole per seat, this one just happened to be in the front instead of the rear.
Related Threads
Nissan 240SX Forums
posts
1.6M
members
94K
Since
2002
