So i started with the wiring last night on the harness. i took the last 3 plugs of the CA harness and cut the 2 plugs off my KA harness and started connecting and soldering wires.
Question 1: For the o2 sensor there is one brown wire coming out of the CA harness and 2 that are coming out of the plug. Do I connect the 2 browns in the plug to the 1 brown in the harness? The write-up said Any 12 volt switch, I didnt know what that meant im not a wiring guy.
Question 2: It said you only needed 2 plugs on the end of the harness, the third was not used. The one with 2 blue wires. do you just cut the plug off and tape the wires up or do they actually go somewhere.
Question 3: After soldering, i was left with 2 wires minus the browns for o2 and the 2 in the plug i didnt need. Im pretty sure one was blue/white stripe and the other was just plain Blue(maybe a dark blue or purple) im sort of color blind but i can still tell that 2 wires are the same or different.
Oh and one last thing. on the CA plug the big one of the two and in the harness was a few wires taped together in gray tape. one big white, one big black that didnt go to anything and one small black. there was no white wires in the KA plug so i just taped the black and white back up and soldered the small black to the small black in the KA plug. do i need to go back and fix?
